Wifi 3G/4G/5G and b/a/ac/ax
wfqk
Level 5
Level 5
Hi Wifi 3G/4G/5G are 3/4/5 generation. while a/b/ac/ax are different band respectively. My question is what is relation between 3G/4G/5G and a/b/ac/ax? Thank you
Leo Laohoo
802.11b = WiFi 1
802.11a = WiFi 2
802.11g = WiFi 3
802.11n = WiFi 4
802.11ac = WiFi 5
802.11ax = WiFi 6
The objective for the "WiFi <NUMBER>" is merely a marketing move.
marce1000
 - You may find an example response below :
     https://www.quora.com/What-is-the-difference-between-WiFi-and-GSM-or-LTE
 M.
Leo Laohoo
802.11b = WiFi 1
802.11a = WiFi 2
802.11g = WiFi 3
802.11n = WiFi 4
802.11ac = WiFi 5
802.11ax = WiFi 6
Thank you!!
