Unable to manage WLC using wired connection
donnie
Hi all,
I am currently able to manage my WLC AIR-CT3504 using wireless connection but no able to do so using wired connection even though i have ensured that i am using the same ip. Please advise. TIA!
7 Replies 7
Sandeep Choudhary
paste the output of these commands:
FROM WLC:  show interface detailed management
SWITCH: sh run int <port> --> where WLC is connected on swicth
Dont forget to rate helpful posts
Hi Sandeep,
Apologies for late reply.
Below is the output. I don't see any issue from the output. Thks.
Interface Name................................... management
MAC Address...................................... 70:18:a7:bb:aa:aa
IP Address....................................... 192.168.1.95
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.1.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::7218:a7ff:fec8:aaaa/64
STATE ........................................... REACHABLE
Primary IPv6 Address............................. ::/128
STATE ........................................... NONE
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
STATE ........................................... INCOMPLETE
VLAN............................................. 1
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (8)
Primary Physical Port............................ LAG (8)
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.1.1
--More-- or (q)uit
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
DHCP Option 82 bridge mode insertion............. Disabled
DHCP Option 6 Opendns Override................... Disabled
IPv4 ACL......................................... Unconfigured
URL ACL.......................................... Unconfigured
IPv6 ACL......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
sh run int
interface Gi1/0/1
switchport trunk allowed vlan 1,100
switchport mode trunk
spanning-tree guard root
Rasika Nayanajith
I would check any ACLs applied onto those wired vlan or wlc management vlan
Rasika
Hi Rasika,
There is no ACL applied on my WLC. I have enabled the option "Enable controller management to be accessible from wireless clients". Thanks
Jurgens L
Level 3
Level 3
Have you tried to put your wired connection on the same VLAN as your WLC management IP and see if you can connect via wired?
Hi Jurgens,
Using wired connection which is on the same VLAN as my WLC management ip, I am able to ping but not able to access my WLC management ip via webUI.
Ok, so that will rule out any network restrictions on the LAN. When you connect to the wireless and you access the WLC, is the SSID mapped to the same VLAN as the Management VLAN?
