Wifi analyzer for DFS interference etc
carl_townshend
Hi All
We keep getting DFS events at one of our sites in the UK and it is causing us lots of issues.
Is there a way we can use an analyzer to find the source of these events?
Also, what spectrum analysis software could I use on my laptop to check for background noise and interference etc?
Many thanks
5 Replies 5
Rasika Nayanajith
I think first of all see how frequency those DFS event occurs and if you can predict when it is going to happen next. With that using spectrum analysis tool (Ekahau Sidekick/ AirMagnet Spectrum XT or Channelizer) you should able to see those in real-time. Channel change could be due to false-positive as well
Here is a very good talk about DFS. Also, refer to the below post on how to use Splunk to analyze those DFS events
https://framebyframewifi.net/2017/02/12/splunking-wi-fi-dfs-events/
Rasika
*** Pls rate all useful responses ***
patoberli
To add to Rasika, Cisco had several updates in the past to reduce the amount of wrong DFS events on some AP models (mostly the AC Wave2 series like 2800 and 3800). It typically also helps to reduce the channel width to 40 or even 20 MHz to reduce the amount of DFS events.
@Rasika Nayanajith& @patoberli have covered it mostly but I was going to say what APs & what software version & what channel width for exactly the reasons Pat mentioned.  We had this problem - all false detections.  Combination of software updates with the fixes Cisco put in + reducing channel width brings the false detections down to a tolerable level  Depending on AP model it's almost impossible to completely eliminate them as the chipset on some models is not as good at reliable DFS detection.
And you should also be aware some devices like motion detectors used for doors, security systems and lighting can use radar which can potentially be a trigger.  Also (UK) some GATSO speed cameras and red light cameras use radar (but unlikely to be that).
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
hi
the access points in question are meraki mr74, the devices that connect are windows tablets with the Broadcom abgn chipset, this is in a new warehouse.
we are really struggling to find what it is.
sometime tmrw we are going to switch off all the tablets to see if it goes away.
you could be right about the lighting also, we could tell them to switch that on with no sensors.
any other ideas ?
I have DFS events on the lakeside part of my buildings. Not sure, but my gut tells me some ship is using a radar in the 5 GHz frequency causing that.
Haven't got any experiences with Meraki though, not sure if the mr74 are more or less prone for false DFS evens.
