Wifi Channels
IrfanKhan4904
Can we use 2,3,4,5,7,8,9,10 channels for Wi-Fi access points?
2 Accepted Solutions
Channels on 2.4 GHz = 20 to 22 MHz wide, but the channel centers are separated by 5 MHz. The entire spectrum is around 100 MHz
For a 2.4 GHz - non overlapping network. Use channel 1, 6 and 11
For the 5 GHz spectrum, you can use all the channels, because the channel width and separation match.
Rich R
You've got the technical details on the previous replies.  Just to summarise:
You can but you should not because channels 1, 6 and 11 are the only non-overlapping channels in the 2.4GHz band.
5 Replies 5
marce1000
 - Also depends on the regulatory domain : https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
 M.
Hi @IrfanKhan4904
  Theorically you can use any channel you want. As per the channels you mentioned above, you are probably refering to 2.4 Gz spectrum which is used mostly for Wi-Fi.
 I am assumiing that your questions come from the fact that using different channels for your access point, you could avoid interference as each AP would be using a different channel. This seems to be a good idea but unfortunatelly it is not.  For 2.4Ghz spectrum, the channels 1,6 and 11 are the channels you can safelly use and thus minimize intererence. If you use channel in between you will fall in another situation called adjacent channel interface which cause as much problem as co-channel interference. Being co-channel interference the interference cause by two access point using the same channel on the same place.
 The best advise is avoid 2.4Ghz as much as possible and try to use 5.0 Ghz instead.
Leo Laohoo
Of course anyone can use those channels.  Any APs will support them.
Will this make WiFi better?  Most definitely NOT.
Rich R
