Wifi Latency
MuhammadSaad_2
Dear All:
Scenario is we have three buildings out of three 2 buildings contain autonomous Access Point and One building contain WLC.
the management and user ssid vlan is same in all the buildings. But when end user connect with User SSID and pings its own gateway is show latency.
Kindly help me in this is very urgent.
Thank You
40 Replies 40
Scott Fella
Don't use uni-2 extended channels also.
-Scott
Clean new config now
With 40mhz and uni-2
Delay <1 ms
With 40mhz and uni-2 enabled or disabled?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Enabled .. to test ;-)
Well it depends on what channel and radio the AP is on.  If your device is connected to the 5ghz and you have an Intel 62xx card with 40mhz enabled, you will have issues.  If your AP is on a uni-2 extended channel, and your client roams to an AP with uni-2 extened, it will fail.  So if you really want to test, set the channel on the AP to channel 108 and see if your client works.   Make sure on the wlan you also set your radio policy to 'A' only.  If you have an intel 6200 card, see if that works also...  It's best to stick with Best Practice and understand what devices you have out there.
Scott
-Scott
Hi Scott
It's a lab setup, one pc with 4965 card and a Google Nexus.
was just wondering what was giving the 45ms delay.
Its something in your configuration... default, uni-2 is disabled along with 40mhz.  So the delay can be caused by the channel, the radio your are associated, etc.  Disable uni-2 extended, because the Google Nexus and the 4965 doesn't support uni-2 extended and if you have any Intel 62xx cards in you environment running less than v15, disable 40mhz.  Now with a default configuration, start making small changes and test.  See what configuration you are doing to cause this issue.  Bottom line, its a configuration change you are making that is causing the delay which most likely is a compatibility issue with the device.
Scott
-Scott
Configured as close to the original config with AIR-CT2500-K9-7-2-111-3 firmware on the controller.
Latency <1ms
Upgraded to AIR-CT2500-K9-7-3-101..... and the latency is back again.
Looks like a serious firmware bug
Downgraded to 7-2-111-3 and rebooted without saving .... still latency :-(
Tested with  AIR-CAP2602I-E-K9  and AIR-AP1242AG-E-K9, it's the same with both, seems like the latency i in the controller.
Upgraded to 8.4.100.0 ... same problem
Delay starts after upgrading the FUS
Factory default and reconfigure, solves the problem.
