WIFI VLANs not communicating
cisco80211
I'm trying to set up 1130 APs connected to a 3750 L3 switch. I set up 3 SSIDs : test,
internal and guest. For some reason, I can't access the APs when the port is configured for trunking. I did the same on a 3560 switch with 2 SSIDs last week, and I'm getting
very different results.
Test: 10.10.10.x Native VLAN 1
Internal: 192.168.10.x VLAN 203
Guest : 192.168.100.x VLAN 202
I connect to the AP fine, but when I connect to 'internal' SSID, I can only communicate
if my IP is on the 192.168.10.x range, even though the 'test'VLAN is set to a different
subnet.
The switch port configs:
interface GigabitEthernet1/0/7 ! ---I can access the AP
switchport access vlan 203
interface GigabitEthernet1/0/8 ! ---no communication---
switchport mode trunk
The AP config:
The AP config should be attached
I'm stuck, I have no idea what I'm doing wrong, PLEASE HELP
Chris Serafin
cserafin@rkon.com
chris@chrisserafin.com
10 Replies 10
john.preves
Level 4
Level 4
These sound like autonomous AP's.
All the ports should be trunked and the native vlan needs to be defined.
Int g1/0/7 has a vlan 203 defined which is why you can get to the AP, g1/0/8 has no vlan
try this:
switchport trunk native vlan 1
switchport trunk allowed vlan 1, 202-203
Try this on one and test it. Then populate the rest of the switch
I have tried this and 2 of the commands do not show up in the config. (must be default configs)
after:
no switchport access vlan 203
switchport trunk encap dot1q
switchport trunk allowed vlan all
this shows in the config:
description [ Link to AP7 ]
Thanks for your original response.
Chris Serafin
cserafin@rkon.com
Not too sure on your case though.I am using 1130 as Lightweight mode,which let the Wireless controller do the configuring.
But one thing for sure, Your AP-Manager and Management Interfaces is recommended to be on the same vlan.hopes that help.
I would at this point write erase and reload the switch and clear out whatever may be lurking in there.
Your getting barked by the switch because you did not set up those vlan's.. I think... Try issuing this statement in config mode
int vlan 202
no shut
int vlan 203
no shut
then go to the interface 1/07 and reissue the statements..
Do a show vlan in global mode to see if your vlan are there..
Hope this works for you..
it worked for me.
I don't have (yet) a VTP domain, so I need to configure vlan on each switch.
Adding it (via the "vlan database" command, since it is an L2 device), and it started working.
ericgarnel
Level 7
Level 7
I may have missed it, but where is your layer 3 device/config that lets the seperate vlans communicate with each other?
rajinder63
can u please change ur native Vlan1 to native vlan203 , u will be accessing then .. no issue .. try it ..
Keep in mind that only the link between the WLC and the wired network should be trunked.
The AP's should be plugged into Access ports.
Correct - sorta. If H-REAP is to be used, the AP is then connected to a trunk port.
