WiFi4EU with Cisco
victor.mansson
Hi all
We are currently installing APs for the WiFi4EU-project and are stuck on getting the captive portal to work accordingly to the documentation.
Accodring to the "Implementation Gudie" we need to add a javascript(JS) to the top of the head tag in the captive portal.
"To obtain correct metrics it is important that the code is located at the top of the<head>tag."
We can't find any product the let us do this.
Have tryed with Cisco CMX (10.3), Cisco DNASpaces and Cisco ISE(2.6).
In Cisco ISE we can add our own JS-files, but it won't let us connect to external JS-sources.
The guide state that we need to add this to the head-tag:
<script type="text/javascript">
var wifi4euTimerStart = Date.now();
var wifi4euNetworkIdentifier = 'NETWORK_IDENTIFIER';
var wifi4euLanguage = 'PORTAL_LANGUAGE';
</script>
<script type="text/javascript" src="https://collection.wifi4eu.ec.europa.eu/wifi4eu.min.js"></script>
Then add this to the body tag:
<imgid="wifi4eubanner">
Have any of you managed to install WiFi4EU captive portal with any of the Cisco products mentioned above?
Thanks!
6 Replies 6
victor.mansson
Also, I have checked the box in ISE under:
Administration > System > Settings > Portal Customization: Enable Portal Customization with HTML and JavaScript
Have you solved it yet?
How did you do?
Lars
Hey Lars
Not yet! But got some info that Cisco is working on a soulution in DNASpaces.
Best reguards Victor
Hi Victor
I have contacted Cisco today as well.
I saw a PowerPoint today that Cisco should have custom portals for that. Booth for DNA Spaces and for WLC.
Lets see what Cisco says.
Lars
Okey, lets keep this thread updated when we get more info.
Hello folks,
I was having the same issue and basically the only option I found is to go with DNA Spaces. I've contacted DNA Spaces support team and told them about an issue I am having; they added snippet manually on backend to the portal. You do need to have customer’s DNA Spaces account and which portal you would like to add snippet (some customer got more portals).
CMX is no go, I was not able to find any proper way adding snippet there.
Hopefully this helps a bit.
