wIPS AIR-OS 5508 and Catalys 9800
Leo TI
Hello I have a question, I have an AIR-OS 5508 (joined to a Prime and MSE) with APs in monitoring mode for WIPS without WLAN and a 9800 for with WLAN and APs for customer service. My question is if I can do WIPS monitoring the WLANs that work on the 9800 like monitoring neighboring WLAN I guess, there is no integration between the controllers.
aWIPS covers a broad range of attacks and features, what is your ultimate goal by deploying aWIPS? Is it only rogue ap detection and containment? If yes then 9800 and Prime is more than sufficient. I wouldn't recommend having monitor mode AP's in one controller and client serving AP's in another controller. Even if you get RRM to share the TPC, channel and neighbor information between controllers, there is a possibility you will see lot of false positives.
From design prospective if you knew aWIPS is a requirement, you must have bought in DNA center. To get aWIPS alerts you can integrate 9800 on non-fabric mode. Just to let you know that starting from 17.6.1 awips alarms can be sent as a syslog message to a remote server.
7 Replies 7
Arshad Safrulla
This is a very interesting topic, my first question will be why not integrate 9800 also with Prime and MSE?
Also if you don't plan it properly all the AP's registered in 9800 WLC will be reported as Rogue AP's in 5508.
the 9800 is not compatible with the MSE, the 9800 series can only be WIPS done at the dna center. So they asked me for the 9800 to manage the wlan for clients and the 5508 to monitor the wlan with wips
Arshad Safrulla
Yes you are correct, Sometime back I remember upgrading some of the MSE appliances we manage to CMX, Cisco provided most of the licenses FOC for us.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/release-notes/rn-17-3-9800.html#:~:text=Compatibility%20Matrix%20document.-,Compatibility%20Matrix,-The%20following%20table
Just check whether you can upgrade your MSE to CMX 10.X where 9800 supported. This will be your option 1.
Option 2 prepare for RRM optimization. You can configure 5508 to share RRM information with 9800, but there are some pre-requisites.
1. RF group name has to be same in both the controllers
2. Upgrade 5508 to IRCM code.
3. Build a mobility tunnel between 5508 and 9800 (optional)
4. Policy tags, rf tags and rf profiles has to match the corresponding AP group name in 5508. Do not use default tags and make sure all the elements in 9800 RF profile match to the 5508 RF profile.
5. Make sure that the new 9800 is RF group leader. (This is selected automatically depending on the WLC capability and size)
This way you can avoid AP's registered in 9800 reported as Rogue AP by 5508.
I already tried the solution of installing the CMX, unfortunately CMX does not have WIPS, which is what the client wants.
And anchor functionality is not compatible with the 5508 model with the 9800 only the 5520 is compatible with the 9800 (or I misread the documentation)
5508 supports IRCM
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc11
https://software.cisco.com/download/home/282600534/type/280926587/release/8.5IRCM
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller-aireos_ircm_dg.html
but cmx does not have wips or can I implement the MSE in with the 5508 and communication with the 9800 ircm?
