Cisco wireless vulnerability
hillstom628
Community Member
Hey all,
I was just browsing around a bit and i stumbled onto this little exploit in the lightweight access-points.
If you have a Wireless LAN Controller (WLC) the LW-AP's will broadcast unencrypted information about the WLC. This enables the hacker to set up a rogue AP's troughout the network. This is a security risk because then the hacker can sniff all the traffic going trough the network.
192.168.10.1
patoberli
I'm not entirely sure what you mean.
Do you mean the CAPWAP traffic between the AP and the WLC on the LAN cable? That traffic is by default unencrypted, like all other PC attached to a switch traffic. You can enable DTLS to encrypt this traffic, if this is a concern for you.
Also the WLC IP address is no secret, as it's in the DHCP packets in every packet in the AP VLAN.
Rich R
What is the specific vulnerability you are referring to?
What WLC model?
What AP model(s)?
What version of code (AireOS or IOS-XE) are you running?
What exactly is your question about the vulnerability?
Like @patoberli already said there is a lot of info available by default - that's not a vulnerability, it's by design.  There are a whole lot of things you should do to design a secure network - many different aspects to network security which is multi-layered.
Serious vulnerabilities in the code will always be fixed by Cisco although it can take a few months for them to release fixed code.
Then it's up to you to upgrade your controllers and APs.
Note that end of life models do not get these fixes so you run that equipment at your own risk.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
