Wired / Wireless
vishal.rane
Level 3
Level 3
Hello All
is the time arrived to replace all wired connection for users with wireless. 95% of the users are laptop users
Assuming:-
new campus with 1000 users with mix of apps users, email users, portal users.
should we still invest on wired for users ( keeping telephony not in the scope )
what is missing in wireless to completely overcome wired network for users
Experts please share your thoughts
thanks
Vishal
So with converged access, its design is really for access points to terminate on a 3850 or any CA compatible switch. There is a roadmap for a cheaper switch in the future. If you don't terminate an ap to a CA compatible switch, then the capwap will have to terminate onto the 5760/3850 that is acting as the Mobility Controller.
So lets not talk converged access. If you use a 5508 for example, you can use FlexConnect for your remote sites and determine what SSID's you want to terminate locally at the site and what SSID's you want to tunnel back through the VPN. So you have various choices, but in your design without a CA compatible switch, your capwap has to tunnel back to the MC.
-Scott
19 Replies 19
Johnjcaston
Community Member
Hi Vishal,,
Provided that the wireless is designed and implemented properly, then there's no reason why wireless can't be used.
You will need to think more about the AP load, not just the coverage, as there might be areas where you may, sometimes, have a high density of users.
Obviously you'll want to make more use of the 5GHz radio due to more non overlapping channels and it suffers from less vendor utilisation than the 2.4GHz spectrum - the downside is that the coverage isn't as good
Bottom line is, make sure that you have a very good AP density in your deployment.
Making use of RRM and CleanAir will help avoid interference and keep the wireless infrastructure operating optimally
I have deployed new sites with wireless only and it they are operating fine, on occasion I've had to add more AP's in certain areas to account for the number of clients
It's a bit of a leap of faith but if you plan and deploy properly, then you should be OK and customers love the added flexibility
Good luck,
John
Hi John, thank you for your feedback
Keeping best practise in mind
  • how many concurrent number of client should be connected to each AP with 3600 series model
  • how many concurrent number of client should be connected to each AP with 2600 series model
is there a method of calculating concurrent users if the devices are smartphones or wireless phones
thanks again
Vishal
Hi Vishal,
You need to think about per user bandwidth you expect to give, I would suggest plan for 30-40 users per AP and plan the cell size accordingly. These AP can support much higher than these values, but if you want to give good experience to users you have to think about capacity.
Adopt as much as 5GHz as it will be the future (at least for next 2-3 years) with 802.11ac waves coming. If you are going to implement any voice, video services (even in future) 5GHz is the best for those. Multicast & QoS is challenging (compare to wired) & thought about those as well.
Also think about WLC models, I would recommend to go with Next Gen WLC (3850 & 5760) with converged access model where you will have more flexibility in time to come. Even though these not supporting 802.11ac now, it is just matter of time & those features will come. If you go with 3600 then you have to get an additional module to enable 802.11ac. I think there will be integrated 11ac AP models in pipe line & will come to market H1-2014.
What is the time line for your implementation.. Decide carefully thinking about future
Rasika
Hi Rasika, thanks for sharing ur thoughts
Are there any document from cisco with best practise and recomendation on the number of clients per AP
i noted ur suggestion.
Here is the Enterprise Mobility Design Guide-Release 7.3 which covers all the fundementals
http://www.cisco.com/en/US/customer/docs/solutions/Enterprise/Mobility/emob73dg/emob73.html
Rasika
Scott Fella
Just to add... You really should talk to your Cisco SE as there are other things that you also need to look at and your requirements is pretty slim. Wireless can replace a lot of the wired things, but not all. You also have to look at your core and access switches also with regards to powering up the AP's. with AC, you need to have 802.at or PoE+. As far as density goes, here is one senecio wireless couldn't be replaced. I had an organization that transfers large amount of autocad drawings to and from various servers. The amount of users in an area, we couldn't provide enough density to move them to wireless. This company relays on the wired side. I also had a customer that transfers video and requires an upload of 3gig to be finished in 30 minutes. We needed up having 3-4 clients max per AP.
In schools, we have no issues with one AP in each room that has usually up to 30 kids. Larger rooms we would double the AP for density. In schools, they might surf the web or have to view a YouTube video.
So it varies with what you really have, but wireless will not replace wired 100%.
As far as the converged access, its really up to your. The parity between the converged access and the current AireOS will not happen until mid to late next year. This is still pretty new and does have its limitations and issues, but will be the direction Cisco will go in a few years.
-Scott
Agree with Scott.
Printers are the main reason why.  Many printers do not support RADIUS/TACACS or even 802.1x.  A lot of printers only support PSK.  So there goes your security.
Wireless laptop ... all you need is one wireless NIC card going "b0nkers" and you can kiss your local wireless goodbye.  If you have that in a wired network, it'll only affect a few users, if you don't have proper switchport security in place.
Remember this main point regarding wireless:  Wireless is a SHARED medium.  If one talks, all the clients have to stop, wait for their turn before transmitting.
Wired network doesn't share this kind of behaviour anymore.
If you have a brand new office and you have the opportunity to kit the place up, get a wireless site survey done.
Just to add so your not looking through pages of docs:  This hasn't changed from back in the days when the 1252's came out.  You are still limited to the gigabit port which you will be oversubscribing.
RF Deployment Best Practices
Some design considerations can be addressed by general best practice guidelines. The following applies to most situations:
•Cisco recommends that for a given AP the number of users per AP be:
–15 to 25 for data-only users
–7 to 8 voice users (using Cisco 792x VoIP wireless handsets or similar) when data is present
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thank you all experts feedback.
All printers,scanner will be equiped with wired network
Cisco partners are involved and site survey for 8 storey building reports/recomendation says
  • max of 4 AP can be installed on each floor  ( we got around 90 wireless users on each floor without smart devices )
  • WLC 5500 series cisco partner recommends ( 5700 series dont support flex connect )
  • 3600 series AP is recommended
  • 2960x series access switch recomended ( cost of 3800 series is high )
  • ISE recommended for guest, wired/wireless control
  • prime recomended for ISE management
5700 specifications are nice with 10G support but not sure why some features are missing when compared to 5500 series, flex connect is one of them
Experts share your feedback on the vendor recommendation
thanks
Vishal
We can't comment on this because we don't know the floor plan.  What country is this this in?
Tell your Cisco people to give you a price for the AP3700.  This model, according to our SE, is slated for release by the end of 2013 and will have 802.11ac natively.
Thanks Leo
Country #  United Arab Emirates
did you had a chance to look at major feature differences between 5700 Vs 5500
For UAE, your regulatory domain is "-E".  So make sure when you put your Bill of Materials, your product ID will read something like CAP3602-E-K9.
I'd go for the 5508 any time.
Make sure you get a site survey done on 802.11a.
Was suvery done for 2.4GHz or 5GHz ?
- If it is around 100 users, I would multiply by 3 (3 devices per user) & allow 300 devices connectivity in each floor. Not sure about the floor area size, but max of 4 mean too little for me.
- Is there any use case for flexconnect in this deployment ? 5500 are still good product & in the market for last 2-3 years. Some point in time Cisco will switch  to 5760/3850 as they are next gen WLC they want to push it in mareket.
- If you thinking about supporting 802.11ac purchase 3600 with the module, otherwise you have to incurr additional cost to install this modue on AP down the track.
- If you compare performance wise 2960 & 3850 are having hugh differences, technically I would go with 3850 (but if budget is an issue, then it is upto you) but keep in mind 2960 is just layer 2 switch & you cannot have layer 3 running with that model.
- ISE & Prime are the primary policy enforcement & Management of Cisco. Good to have those two products.
Rasika
