Wired / Wireless
vishal.rane
Level 3
Level 3
Hello All
is the time arrived to replace all wired connection for users with wireless. 95% of the users are laptop users
Assuming:-
new campus with 1000 users with mix of apps users, email users, portal users.
should we still invest on wired for users ( keeping telephony not in the scope )
what is missing in wireless to completely overcome wired network for users
Experts please share your thoughts
thanks
Vishal
19 Replies 19
Saurav Lodh
Level 11
Level 11
PFA for IT best practices for WLAN deployment. Its a short doc , very informative though. Hope it helps
Scott Fella
Here is my 2 cents....
Like Rasika mentioned, you now have to look at density no matter what. You either take the number of users and multiple by 2.5 or 3 to be safe and that is how you will determine how many APs you need. I would go with 20-30 max devices per AP also and any large conference rooms or training rooms would get two AP's.
Now you need to look at what you what to do for wireless. The 5760/3850 doesn't support FlexConnect because its a different technology. Since AP's terminate capwap directly at the 3850, FlexConnect isn't needed. The design for converged access is similar to FlexConnect as all traffic is terminated at the switchport and not tunneled back. Now there are some reasons why traffic would get tunneled, but I will not go through that here.
Would I invest in the 3850's... Yes, but also talk to your SE about the lower end switch that will support CA:) you can also do a hybrid setup with 3850's or the newer switch and a 5508 if you wish. The one thing to note is that the license will not transfer from a 5508 to any converged access controller unit acting as an MC. So if you decide to go with the 5508 and later want to go CA or replace the 5508 with a 5760, you will have to buy licenses.
I too would go with the 3600's or even the newer AP, if it does come out in time, but this depends on when your deployment is. ISE is not cheap and Prime is nice to have especially if you go to CA. I have clients that don't have Prime as its not needed to make your wireless work. It's really recommended if your using CA and with the newer version that will work we'll with ISE. With ISE, you need to spec out that correctly depending on how large of an environment you need to support and that's where it starts to cost. It's a good product though, just expensive.
-Scott
Abhishek Abhishek
The Cisco Unified Wireless Network is designed to support real-time business-critical applications and create a secure, mobile, collaborative workplace for organizations deploying wireless LANs. Whether you already have a wireless network in place or are building a new wireless solution, our services can help you create a sound, scalable wireless design that enables rich media collaboration. This service is designed to help you incorporate a variety of mobility services and applications allowing for smooth solution integration while avoiding costly delays during implementation.
● Voice and Video: Create the dependability, performance, and security needed for sensitive Wi-Fi voice andvideo applications including support for phones and tablets
● Guest Access: Allow guests, vendors, and partners to access the Internet while keeping your internalnetwork secure and easy to manage
● Outdoor Wireless: Deploy a secure and cost-effective outdoor wireless solution with a designthat transparently integrates voice, data and video applications
Service Data Sheet
© 2010–2011 Cisco and/or its affiliates. All rights reserved. This document is Cisco Public Information. Page 2 of 10
● Context-Aware: Increase the accuracy, speed, and efficiency of your context-aware solution to locate usersand track critical business assets on the network.
● Adaptive Wireless Intrusion Prevention Systems: Protect your network from wireless threats with asolution designed to optimize RF coverage and performance.
Assistance includes configuration of wireless LAN security, controllers,wireless LAN network management, Cisco Mobility Services Engine, Cisco Wireless Control System, the 802.11x standards, Cisco CleanAir, and Cisco access points to support productivity-enhancing mobility applications and diverse Wi-Fi-enabled devices, including phones and tablets.
thanks everyone
Scott, @ HQ lets say 5760/3850 deployed and remote offices got 2960 POE switch with 3600 series AP - will the remote office AP register to central HQ
Remote office connects to HQ over ipsec vpn
thanks
Vishal
So with converged access, its design is really for access points to terminate on a 3850 or any CA compatible switch. There is a roadmap for a cheaper switch in the future. If you don't terminate an ap to a CA compatible switch, then the capwap will have to terminate onto the 5760/3850 that is acting as the Mobility Controller.
So lets not talk converged access. If you use a 5508 for example, you can use FlexConnect for your remote sites and determine what SSID's you want to terminate locally at the site and what SSID's you want to tunnel back through the VPN. So you have various choices, but in your design without a CA compatible switch, your capwap has to tunnel back to the MC.
-Scott
