Wireless 5508 802.1x Part 2
JohnTylerPearce
Level 7
Level 7
With stephens help I was able to get most of my Wireless 802.1x setup configured properly. I'm not having a problem with the client authenticating using user/pass credentials. I have a Wireless XP Client (testing with), which connects to a LWAP, which connects to a WLC 5508, and then Cisco ACS for authentication. I put in my user credentials of tylerp (test account) with the correct password but nothing happens, it just keeps asking me to enter in
credentials after a few seconds. I started Wireshark on my laptop and I can see the following.
Source
Cisco_1e:3a:8f
Destination
IntelCor_85:9e:46
Protocol
EAP
Information
Request, Identity [RFC3748]
It looks like it's asking the client for credentials but when I submit my credentials I dont see any response via wireshark. I'm not sure why that is.
I have included several photos from my WLC/ACS configuration. Any help would be great!
77 Replies 77
In the client, which setting did you pick?  Microsoft Protected EAP (PEAP) or Microsoft Smart card or other certificate?
for PEAP it should look like this.  You can uncheck the Validate server certificate box, so you don't need to push the ACS cert while testing.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Looks like we're making progress here. Here is a new monitor log from the ACS.
ok, so still getting the Selcted Identity Source is Deny access.  In the policy, are you allowing AD?  And in the AD config of the client, did you select the grant dial-in permissions?
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
You are not hitting your SecureWireless profile. You need to define your network access policy better so that ACS can differentiate between that policy and the SecureWireless.
Scott Fella
Sent from my iPhone
-Scott
What is using the network access policy? Can you disable that for the mean time just to see if the SecureWireless policy is being hit.
-Scott
Scott Fella
Did you add the WLC to its own NDG? I see that your network access policy is for your VPN and your rule base is using NDG and VPN Database, but your wireless is hitting that policy. For your network access policy, you can add a lookup for nas ip address and use the ip of your VPN device. That should make it hit your SecureWireless policy.
-Scott
I'm still getting the error message. I must not be configuring the access policy correctly. Which I'm sure you know..
Change your VPN rule base and your wireless rule base to add device ip.
For example:
-Scott
Well, I tried a few things you suggested. I'll throw in some pictures. It's still giving the same identity error message.
Good News!!!! Problem has been fixed. I will include the following screenshot, which has the solution. Maybe you can help me understand why it worked doing this.
BTW, points will be dished out to everyone that helped! I got to do a few things shortly, but trust me, points will be dished out
Before the service selection was Radius, Tacacs+, then dot1x. Putting dot1x at the top did the trick. Someone may have mentioned that
in one of the previous posts, it's just been such a long discussion...
Just make sure your VPN is working also.
-Scott
I tried that afterwards and had to move the dot1x to position 3 because VPN stopped working as far as authentication goes. Now I know the problem is with hte selection policy.
Please correct me if I'm wrong. If I create a "service selection policy" such as dot1x, which I have already done, and then I made it to the Secure Wireless Access Policy, and move it to the top of the selection order. Whenever something comes
into the Cisco ACS wanting to authentication via RADIUS, it's going to match dot1x and try to run the access policy of SecureWireless. So when I moved this to the top, that's why it worked, but when I tried to VPN, it matched the first rule which was dot1x, and the AD groups I have selected for the Network Access Access Policy, are not there, since it goes to SecureWireless.      If that's the case, my question is, How can I order the service selection policy so both of these will work?
