Wireless Access Point (IW3702-4E)
collrbbrt
Level 3
Level 3
Hello guys I have a new Wireless Access Point model IW3702- 4E that is connected to a POE port on Switch model WS-C4510R+E.
It starts with and shows a few solid and flashing lights but after no Lights remain stable. Seems it is not fully loading the ios. I could be wrong but any one with an idea about this and what I can do.
(view in My Videos)
8 Replies 8
Leo Laohoo
Console into the AP and reboot.
Post the entire boot-up process.
Mark Elsen
  - After the observed led sequence has completed ,  on the WS-C4510R+E. , issue the command show cdp neighbors detail ;     what outputs do you get for the switchport where the AP is connected to ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
No cdp nei is returned in the result.
When I connect another New Ap on same int the new Ap is working fine. So it is clearly an issue with the AP.
        >...When I connect another New Ap on same int the new Ap is working fine
  - You will need to take the AP down attach a console in a 'lab environment' and observe the boot process
 M.
- Not good , this means a normal startup could not be completed. How is
the AP powered ?.
M.
Using PoE with M12 X-code.
Same code worked on new AP
- Make sure the particular port has LLDP enabled ,
M.
