Wireless Access Point Maximum Users
One of my customers has requested for a wireless solution for a production area in a factory .Actually there are 400 locally customized (automatic) devices needs wireless connections to share some small files (approx 80kb per file) data to be shared will be very light through the wireless network , premises area is 50*35 meters (fully open area) so i suggested four 1702i access points for them , coverage is perfect with four access points but my question is , is it enough four access points for this solution ? what is the maximums client count can recommend per 1702i AP ? If I increase AP's, will the channels overlap?
Rajitha
18 Replies 18
Ok, this means it indeed crashed some when. It sadly didn't print the date when 😞
If you issue a "show flash" or "dir" it should show you all the files, including the crashfile with a date. It could be a very old crash file.
In any case, I suggest you to upgrade to the latest firmware and if this doesn't help, directly contact Cisco or your reseller as this crash dump could mean a hardware error.
I can not download the firmware due to I just end-user without service contract with Cisco. It is great if you could do it for me and put it to cloud like Google Drive.
Thanks a lot.
Thang
Sorry can't do that, it's against the rules.
Thanks for your help so far.
Thang.
