Wireless Access Point MIC certificate warning
Sharath Karpur
Level 3
Level 3
Hi All,
Hope you are all doing well !
I have set an special SNMP monitoring for AP MIC certificate expiry date on my monitoring system.
For WLC i could add the MIC ignore command "
config ap cert-expiry-ignore {mic|ssc} enable
But how to deal with AP MIC itself, is there any optional command to ignore the warnings.
"Manufactured 2010/10/04 - grace period of 3460 days exceeded for 35 days"
Sharath
pieterh
I don't understand what you are trying to achieve?
you setup "special monitoring" for certificate expiry and then you want to ignore the warnings that come out of this monitoring?
