08-20-2013 05:51 AM - edited 07-04-2021 12:41 AM
Hello
I have the following ACS's. They are VM
Cisco Secure ACS
Version : 5.2.0.26
I have been having trouble with the Primary hanging up, but the secondary does not take over.
I have spoken with TAC and they advised me to upgrade the software to stop the hangup, but I am not sure why it does not failover.
What can I check to make sure the triggers are in place and working properly?
Solved! Go to Solution.
08-21-2013 06:36 AM
If your ACS is a primary secondary and the primary gets hung up but the secondary still doesn't take over the primary role, then you might have an issue with the primary and you should maybe promote the secondary as the primary and fix the issue with the primary. This is what you have to troubleshoot. because the WLC will still send request to the primary if that is how it is defined in your wlan, until the primary doesn't respond and is marked dead.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
08-22-2013 02:14 AM
Well, You need to make sure that the primary server is really down. Then the AAA clients need to failover.
When the server is shown to be down is it pingable form the AAA devices?
If the primary is really down and that is detected by the AAA clients, the AAA clients will then automatically failover to the next configured AAA server (if it is correctly configured).
What you'r AAA clinets? I think debugs/logs form the AAA clients are needed to make sure that they detect the primary server as down and to see if they failover or not.
Amjad
Rating useful replies is more useful than saying "Thank you"
08-21-2013 04:16 AM
Hello Steve.
What do you exactly mean by the secondary is not taking over?
Do you mean that:
1-) You are not able to login to the GUI of the secondary for configuration.
or
2-) Your AAA clients do not fall over to use the secondary server if the primary server is down.
Amjad
08-21-2013 06:03 AM
Amjad
My AAA clients do not fall over to use the secondary server when the primary server is hungup.
08-21-2013 06:26 AM
Steve:
well, then you may need to check and make sure your AAA clients are having both ACS servers added as RADIUS servers. The fallback (for AAA authentication when one server is down) happens on the AAA client side, not the server side.
Have you added both servers to the AAA clients?
If no then please make sure both server ip addresses are added. Then, when one server is down and the AAA client experience a timeout for a request to one server it will fallover to the next configured server.
Amjad
08-21-2013 06:47 AM
Amjad
Where, exactly would the servers be added, (ACS?, WLC?, WLS?)
These devices were setup by contractor. I am 99.9 % sure the servers are defined, I justr am not sure where to look for them.
08-21-2013 12:48 PM
Ok
The AAA servers are configured on each Controller. My controllers have both servers defined with Server1-Primary
Server 2-Secondary. Based on what I see, failover should occur. What else should I check?
08-21-2013 03:20 PM
Failover will only occur if the primary doesn't respond. If the primary responds even though its hosed up, the wlc will not failover.
08-22-2013 02:14 AM
Amjad
08-23-2013 07:18 AM
Amjad
The issue has been the "hangup" does not cause the server to be completely down.
The fix we are applying this weekend is to first add the 5.2 patch and then upgrade s/w to 5.3. We are only going to apply
to one of the servers, then run on that server for a week or so to make sure there are no other issues that develop. Hopefully
all will go well, we can upgrade the 2nd server, restart replication and move on to other fires.
Thanks for the input.
08-21-2013 06:36 AM
Scott
