Wireless Antennas
rx33328
Community Member
We have in our factory AGV's(Automated Guided Vehicles) that roam about the factory. I would like to connect those to our wireless network using 350 workgroup briges. I need to mount the WGB under a hood of the AGV and mount the antenna outside. Is there an antenna that I could use that would remotely attach to a 350 WGB via a 12 -24 inch cable? I know that I would have to use the model AIR-WGB352R w/dual RP-TNC connectors. I'm just looking for antenna options. Thanks..
derwin
Level 10
Level 10
Most of these will work with the WGB (the only one that wont are the ones for the LMC cards)
http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a0080092285.html
AIR-ANT1728 sounds like a good choice for this applications depending on what mounting options you have
l.roberts
Community Member
You need omni antennas. Omni antennas provide a 360 degree coverage area. This is the best solution for a roaming type of vehicle. I would also recommend LMR-400 coaxial cable to connect the WGB to the external antenna. Check out the following site:
www.fab-corp.com
These guys are very helpful and have everything you need.
HTH,
Larry Roberts
CCIE #7886 (R&S / Security)
