Wireless Backhaul
nuno.casanova
Frequent Visitor
Frequent Visitor
i have a request to implement a wireless point to point solution with Cisco equipment.
the request is to connect too point´s that distance about 2 km apart.
dose any one have a suggestion about the equipment to use?
thanks
Hello Nuno,
Maybe this document helps:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-mesh/111451-indoor-mesh-deploy-guide-00.html
As to which antenna can be used that depends to what the range should be.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/2600/quick/guide/ap2600getstart.html#pgfId-59090
For Point-to-point bridge configuration please go through the below links
http://mrncciew.com/2013/01/18/workgroup-bridge-wgb-configurations/
He also has some more info on configuring bridges:
http://mrncciew.com//?s=bridge&search=Go
Hello Nuno,
