Wireless Barcode Scanners Getting Disconnected Randomly
jain.manish94
Hello Team,  users are disconnecting between when they are using barcode scanners . first I did changes band 5ghz but feedback was very bad. Then I set 2.4g still they are facing issue . What to do now.
22 Replies 22
Scott Fella
Couple things you should do, open a TAC case so they can look and or hire a professional services company to site survey, review and troubleshoot the issue. A forum is a very hard and slow when it comes down to real investigating. Some general opinions was provided, but without seeing the config, talking with users, trying different things and performing a site survey, there is no one answer.
-Scott
But other devices are working In that area like laptop without any issue. Do u have any idea from scanner prospective if any changes needed.
Jurgens L
Level 3
Level 3
You will need to first make sure that the physical layer of your wireless network is operating as expected. Therefore a wireless site survey will be required, using proper software such as Ekahau or iBwave. The survey will not only verify the coverage but also other important things to check such as co-channel interference and signal to noise ratio.
Understand the operation limitations of your end device when it comes to RF, so you can relate that to the results of your survey.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
But these are wireless barcode scanner how to check physically.
And plz help me how to use site survey software at the site I mean to say I need to install in any laptop at the site ?
Or there is other method to do so.
To do the survey you are going to need Site survey Software like Ekahau, and wireless survey adaptors that are able to scan all the channels like a NIC-300 card or a Ekahau Sidekick.
I'm going to say if your not sure of wireless site survey software, that I would be recommending hiring a third party company to conduct the site survey and produce a report detailing the coverage/ capacity of the existing wireless network. Given the warehouse environment being a complex environment this will be the best way to discover the issues, especially since you will be looking close to the same cost to get them in, compared to purchasing the survey software and equipment.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
Let me guess, the APs are Aruba, right (LINK)?
No this time cisco
No this time cisco
Ok, so the barcode scanners are having problems with both Aruba and Cisco wireless.
What changes were done to the barcode scanners?
No changes did on scanner yet. I don have idea what I say them to change on scanner.plz tell me.
Dennis Mink
what Cisco wireless product are you having troube with?
Please remember to rate useful posts, by clicking on the stars below.
Barcode scanner intermec c3k
Has the bardcode scanner worked before?
From last 2 mpnths they are facing this issue before it was not a big but now it is.
So it has never worked.  Correct?
What firmware is are the scanners loaded with?
Have you verified the behaviour yourself?
