Wireless Bridge Stops Working Spontaneously
trevorjackson
Community Member
I have a 350 series wireless bridge and every so often it will just stop working until it is power cycled. Before power cycling it, the LED's will just all be on solid. I did have a power spike a few weeks back that damaged other equipment that was in the same surge protector. It may be possible that this device was damaged as well. Can someone give me some advice to troubleshoot this problem? It's tricky because the device will work for days/weeks at a time and then just stop functioning until it is power cycled. Any help is greatly appreciated.
gamccall
Level 8
Level 8
There's a bug in some code versions which will cause an AP to lock up if it receives a packet containing certain bit patterns. Try updating to the most current firmware and see if that resolves your issue.
Which version of code has an issue? Thanks
