wireless capture
Hi everyone; please help me,i want to know how to capture about ap and wlc. thanks
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Rasika Nayanajith
Pls refer below links,
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/80211/200527-Fundamentals-of-802-11-Wireless-Sniffing.html
If you have Cisco AP, then you can change it to "sniffer mode" and used it with wireshark to wireless packet capture. See below
https://mrncciew.com/2018/04/07/wifi-captures-with-sniffer-mode-ap/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Hi Rasika ;
Thanks for your help,and whether it can capture on WLC?
Sniffer AP capture the traffic that AP's upstream and downstream,right?Can we Capture WLC's upstream and downstream on WLC ?
Thanks~
From the WLC itself, you can't capture. Easiest way to span WLC connected switchport to a PC running wireshark. In that way you will capture all traffic going between WLC <-> APs and WLC to rest of your wired network.
No, It is not capturing its own traffic.
Sniffer mode AP captures what's happening on a particular channel that you set on sniffer mode AP. Sniffer mode AP just simply listening on a particular channel.
Rasika
HI Rasika;
Thank you for your answer~
