05-20-2007 02:50 AM - edited 07-03-2021 02:05 PM
I have a HWIC-AP-AG-A card in cisco 1841 router. But the router can not recogneise the card. The show diag can see the card, but show ver can not find the card.
Any one know which IOS version and feature set support wireless card in cisco router?
WIC/HWIC Slot 1:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
PCB Serial Number : FOC09363ZHY
Hardware Revision : 1.0
Part Number : 73-9388-03
Board Revision : A0
Top Assy. Part Number : 800-25210-01
Deviation Number : 0
Fab Version : 03
CLEI Code : IPUIANDRAA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-AP-AG-A
Version Identifier : 01
Unknown Field (type 004A): 00 00
EEPROM format version 4
EEPROM contents (hex):
Cisco-1841-ADSL-Wireless#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 24-Apr-07 13:29 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Cisco-1841-ADSL-Wireless uptime is 4 minutes
System returned to ROM by reload at 08:01:34 UTC Sun May 20 2007
System image file is "flash:c1841-adventerprisek9-mz.124-13b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 1841 (revision 6.0) with 116736K/14336K bytes of memory.
Processor board ID FHK1106151N
1 DSL controller
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Cisco-1841-ADSL-Wireless#sh flash
-#- --length-- -----date/time------ path
1 25490280 May 20 2007 07:59:48 +00:00 c1841-adventerprisek9-mz.124-13b.bin
21291008 bytes available (42721280 bytes used)
05-20-2007 04:28 AM
Hi Kevin,
Here is a clip from Ben's (from Cisco) excellent post (he knows more about this than I ever will :)
Yes, the HWIC-AP is supported with the 1841, but you must be running a 12.4T IOS image (in addition to the correct feature set). I'd suggest 12.4(11)T with Adv. Security or Adv. IP Services Feature Set. Make sure you meet the minimum memory requirements as well.
Your next best option would be 12.4(9)T2 with either Adv. Security or Adv. IP Services Feature Set.
Hope this helps!
Rob
05-21-2007 12:34 AM
Thanks, Rob
I only have 128MB memory in my router, so I can not use Adv. Security or Adv. IP Services Feature Set, they need 194 MB memory.
I used c1841-spservicesk9-mz.124-11.T2.bin file, I can see the wireless card now.
Kevin
