Wireless client automatically roam between channels?
william.ong
Community Member
Hi, does a Cisco aironet 350 client automatically roam between APs on different channels if I use the same SSID? Let's say I have an AP of channel 1 and on AP on channel 11.
fjuch
Yes, that is the way it works. Be sure the access points are all the same brand. Different brand APs do not have a standard to pass off clients to each other.
