Wireless client lose or have a problem to connect Ap.
lucasfreitas83
Hello everyone,
I have WLC 2504(8.2.161.0) and Aps 1702I(15.3(3)JC8) and 1602I(15.3(3)JC8).
I have 3 problems.
1º When you try to connect to the SSID Corp, for example, the connection is delayed or not connected. If you try again, the connection may successful.
2º After a stable connection, some clients end up losing connection (even though they have not been launched in the place) and the return signals, returning to stage 1.
3º Some of these clients sometimes after connecting receive the message that the connection is limited, but does not perceive problems, the client can use the network and normal browsing.I have already updated the wireless card driver, set a fixed DNS to isolate, have already tested on other devices and have the same symptom.
In the logs of APs I see why sometimes the radio interfaces flapping are down/UP.
ADM-AP04
Oct 30 11:59:59.915: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Oct 30 12:00:00.915: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
Oct 30 12:00:00.963: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Oct 30 12:40:46.859: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
Oct 30 12:40:47.023: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Oct 30 17:46:32.519: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Oct 30 17:46:33.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
Oct 31 18:55:00.515: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Oct 31 18:55:01.527: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
ADM-AP10
Oct 30 12:50:57.111: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Oct 30 12:50:58.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
ADM-AP11
Oct 31 13:32:13.166: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
However the times and amounts of time the problem occurs does not hit. I have more incidence of the problem than the one reported in the logs
These are the last logs of the controller
*apfMsConnTask_3: Nov 03 08:21:34.211: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:da.
*apfMsConnTask_4: Nov 03 08:21:29.383: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_3: Nov 03 08:21:18.492: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*Dot1x_NW_MsgTask_1: Nov 03 08:21:15.763: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:449 Invalid replay counter from client 00:10:20:59:9b:c9 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*apfMsConnTask_1: Nov 03 08:20:52.907: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:5d.
*apfMsConnTask_2: Nov 03 08:20:51.030: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:6c:fd:fa.
*apfMsConnTask_5: Nov 03 08:20:50.275: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*Dot1x_NW_MsgTask_5: Nov 03 08:20:49.475: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:449 Invalid replay counter from client 98:39:8e:5c:60:dd - got 00 00 00 00 00 00 00 03, expected 00 00 00 00 00 00 00 04
*apfMsConnTask_7: Nov 03 08:20:49.310: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*Dot1x_NW_MsgTask_6: Nov 03 08:20:46.722: %DOT1X-3-INVALID_WPA_KEY_STATE: 1x_eapkey.c:2532 Received EAPOL-key message while in invalid state (4) - version 2, type 3, descriptor 2, client e0:b5:2d:82:60:66
*Dot1x_NW_MsgTask_4: Nov 03 08:20:40.926: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:449 Invalid replay counter from client 00:23:68:fc:a3:cc - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*apfMsConnTask_3: Nov 03 08:20:36.143: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:5d.
*apfMsConnTask_7: Nov 03 08:20:35.451: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:6c:fd:fa.
*apfMsConnTask_7: Nov 03 08:20:33.335: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*apfMsConnTask_5: Nov 03 08:20:29.112: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_5: Nov 03 08:20:23.658: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_2: Nov 03 08:20:22.752: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*apfMsConnTask_5: Nov 03 08:20:12.009: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*apfMsConnTask_7: Nov 03 08:20:11.265: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:5a:d0:9c.
*apfMsConnTask_4: Nov 03 08:20:05.362: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*apfMsConnTask_3: Nov 03 08:20:00.031: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_4: Nov 03 08:19:54.918: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_5: Nov 03 08:19:54.353: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:5a:d0:9c.
*apfMsConnTask_4: Nov 03 08:19:50.941: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:5d.
*apfMsConnTask_5: Nov 03 08:19:33.251: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_3: Nov 03 08:19:32.090: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*apfMsConnTask_4: Nov 03 08:19:31.523: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:da.
*apfMsConnTask_3: Nov 03 08:19:13.490: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:5a:d0:9c.
*apfMsConnTask_4: Nov 03 08:18:53.890: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:bc.
*apfMsConnTask_3: Nov 03 08:18:47.481: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:da.
*apfMsConnTask_4: Nov 03 08:18:38.874: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_3: Nov 03 08:18:14.742: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:5d.
*apfMsConnTask_3: Nov 03 08:18:07.944: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:9b:21.
*apfMsConnTask_4: Nov 03 08:18:00.755: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:59:99:da.
*apfMsConnTask_1: Nov 03 08:17:54.239: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:10:20:5a:d0:9c.
*Dot1x_NW_MsgTask_2: Nov 03 08:17:43.929: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:449 Invalid replay counter from client 00:10:20:59:99:da - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*apfMsConnTask_7: Nov 03 08:17:40.681: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:216 Could not check supported rates. Invalid Supported Rates from stat 00 00 00 03
Please, does anyone have any ideas to check?
Hey People,
I resolve my problem with an update the controller to version 8.3.133.
Thanks a lot.
8 Replies 8
Leo Laohoo
Check the data sheets or specification of the wireless clients and compare the data rates enabled on the controller.  This log states that the wireless client is (possibly) only configured to support low data rates while your controller is configured for high-speed data rates.
Leo, thanks for your comment.
I have collectors wifi, this error referer these collectors. I don't see the same error in MAC of the clients.
Hey People,
Thanks a lot.
What model APs where you having this problem with?
Thanks!
The Ap models are (1600 - 1700 - 2600)
Be careful when applying 8.3 updates.  Many APs will only work with 8.0.x.  Read the notes for supported APs before applying any updates or you will lose half of your wifi AP's.
All Aps work well in the WLC with new firmware.
APs 1600 and 1700 not have problem in 8.3.
My problem is the clients losing the connection with AP.
d.friday
Level 4
Level 4
Did you turn off some of the data rates on the WLC, if so turn then back and see if that helps.
David
