wireless client not joining
hazemelebiary
Visitor
i have wireless client sometimes join and sometime not
i have wlc 4404 OS 6
I don't use any AAA server just local authentication
i enabled debug on the client and i have those out put but cant tell what is the problem
client MAC B8:5A:73:5E:F1:88
I have another client  60:57:18:6A:50:A9 which is successfully joined
attached logs for both clients
Stephen Rodriguez
So from what I'm seeing in the debug, the client is getting authenticated just fine, what is failing is DHCP
 b8:5a:73:5e:f1:88 DHCP   requested ip: 172.18.34.21
The client is requesting this address, but none of the DHCP servers ever reply to this request. You may want to check logs on your servers.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
abwahid
Level 9
Level 9
Make sure, is there any restriction enable for this MAC address B8:5A:73:5E:F1:88
at server side.
Sandeep Choudhary
Totally Agree with Stephan. There is something wrong with DHCP.
Could you enable or Disable DHCP rpxy on your WLC and try again.
Controller > Advanced > DHCP
Dont forget to rate helpful posts
