wireless client PCs do not get ip address
pcfreak49
Level 7
Level 7
I have a problem, the wireless client PCs do not get ip address via DHCP how can you fix this?
Good to hear that. You are welcome
Madhuri
13 Replies 13
Roman Rodichev
Level 11
Level 11
you are gonna need to tell us more than this
autonomous access points? post config
controller based aps? post screenshots of WLAN pages and interface pages (or show run from controller CLI)
how are the APs connect to the network?
I subinterfaces created on a Cisco 892w router ssid and then another to make the clients get no ip address 20.20.20.1 255.255.255.0 that are awarded
the ssid is in vlan 2 IS, I do not know what I've done
This is the running-config and running-config ap
configuration looks pretty good actually
try disabling spanning-tree with "no bridge 2 protocol ieee"
also, try configuring static IP on the client, can you ping 20.20.20.1?
can you do "show interface wlan-gig0 switchport" and post here?
I have the client a static ip address, but which can not connect to the router this is the show interface output port WLAN switch gig0
Switch Port: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1 to 2.4
Protected: false
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Leo Laohoo
Just to test, try with OPEN authentication.
I just tried with Open authentication and the client get no ip address to gekent and a static ip address if I do not succeed
If you connect a wired PC to Router directly and put the port in Vlan 2, will that get an IP address ?
Is vlan 2 in the data base and is interface in UP state in router ?
Madhuri
Yes, I have the PC in vlan 2 and put that work the client gets an ip address
Can you issue the following on AP and test :
1. ping 20.20.20.1 source bvi 1
2. I see that you have all the data rates set to basic which could be a problrm for client to connect. Try
conf t
int dot11 0
speed range
and test
3. What happens if you map ssid to vlan 1 ? Will it work fine ?
If that works fine, make sure that you have added vlan 2 in allowed vlan list on the trunk port
Madhuri
it works really heartfelt thank you because I had to spend long hours on searching
Now it works, I would like to assign IP address specifies a mac to the same ip address dhcp server
Madhuri
thanks Madhuri for providing the info.
Thanks & Regards
I would like to create an SSID with a different IP address but get no dhcp?
