Wireless Clients losing connectivity on 9800 WLC SwRls 17.3.3
olavarr
Does anyone know if there's a bug on this code contributing to this problem we are experiencing?
Controller could not validate “PMKID” for fast roaming, and then association failed to 1Park-15FL-AP20, and controller then performed a client deletion due to client sending incorrect PMKID during EAPOL 4-way handshake, see snipit in Figure 1.
Surendra BG
[dot11-validate] [19551]: (ERR): MAC: 8c8d.2844.b2c7  Failed to Dot11 validate dot11i pmkids.  Pmkid validation failure, Type of pmk cache is not RSN
2021/09/23 14:25:48.816679 {wncd_x_R0-0}{1}: [client-orch-sm] [19551]: (info): MAC: 8c8d.2844.b2c7  Deleting the client, reason: 54, CO_CLIENT_DELETE_REASON_DOT11_INVALID_PMKID, Client state S_CO_L2_AUTH_IN_PROGRESS
2021/09/23 14:25:48.816710 {wncd_x_R0-0}{1}: [client-orch-sm] [19551]: (note): MAC: 8c8d.2844.b2c7  Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_DOT11_INVALID_PMKID, fsm-state transition 18|28|33|42|44|46|48|4d|5c|5e|7f|82|8a|13|17|18|28|33|42|44|46|48|4d|5c|5e|7f|82|8a|13|14|2d|10|
Check this bug :  https://cdetsng.cisco.com/summary/#/defect/CSCvx27626
Question : Is this seen on Apple clients?
see if this workaround works
<B>Workaround:</B> Disable 802.11r or Configure mobility group name after switchover to recover from the issue
Surendra BG
cdets is only accessible to Cisco staff - we need to look at bug search tool: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx27626
Note that's fixed in 17.3.4 so if it is that bug causing the problem then you should be able to upgrade to 17.3.4 quite easily.
