Wireless Controller utility port
seegomaa
Level 3
Level 3
any body can tell me what is the function of utility port on 4402 controller ?
Hi Mohamed,
Just to add a note to the good tip from Andrew (+5 points Andrew 🙂
I have searched high and low and have spoken with some experts about the Utility Interface and all they can tell me is that it is reserved for "Future" use and serves absolutely no function at this time.
Here is the relevant clip;
"Note: Figure 3-2 shows a Cisco 4404 controller. The Cisco 4402 controller is similar but has only two distribution system ports. The utility port, which is the unlabeled port in Figure 3-2, is currently not operational."
Cisco Wireless LAN Controller Configuration Guide, Release 5.0
Configuring Ports and Interfaces
http://www.cisco.com/en/US/docs/wireless/controller/5.0/configuration/guide/c5mint.html#wp1113882
Hope this helps!
Rob
Hi Mohamed,
Hope this helps!
Rob
Rob - thanks mate, much appreciated.
