Wireless Deployment
afernandez0226
Frequent Visitor
Frequent Visitor
I want to build autonomous wireless N network with about 10 indoors AP and 3 Outdoors AP. I have Cisco 3560 PoE switchs. The network will have IP phones. Can you guide me to the right AP to buy.
I forgot to add that I need this deployment to be done ASAP. So much appreciated
6 Replies 6
Leo Laohoo
Try the following:
Cisco Product Advisor
http://www.ciscowebtools.com/ProductAdvisor/
For AP's that are geared up for 802.11N (Draft 2.0):
Data Sheet Cisco Aironet 1140 Series Access Point
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502793.html
Data Sheet Cisco Aironet 1250 Series Access Point Data Sheet
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/product_data_sheet0900aecd806b7c5c.html
If you are going to choose the 1250, note that the Antennaes are optional. Here's some information regarding them.
Antenna Product Portfolio for Cisco Aironet 1250 Series Access Points
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
The AP1250, when operating with 2 radio modules on Autonomous IOS, requires a minimum of 18.5 watts (ePoE). So you'll need either a Power Injector or PoE switch that will support enhanced PoE such as the 3560-E or 3750-E.
802.11n Design and Deployment Guidelines
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_80211n_design_and_deployment_guidelines.html
Hope this helps.
Hey Leo,
Great post my friend! +5 points for this very detailed answer.
Cheers!
Rob
Leo Laohoo
Thanks for the rating, Rob.
Leo Laohoo
Hi Antonio,
Before you begin purchasing the necessary equipment, have you considered conducting a Wireless Site Survey?
With 10 Indoor AP's, would you consider for a Wireless LAN Controller? I'd recommend the WLC-4402-25.
Data Sheet Cisco Wireless LAN Controllers
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps6307/product_data_sheet0900aecd802570b0_ps6366_Products_Data_Sheet.html
I am using AirMagne for the site survey. Right now I have not budge for the Wireless LAN Controller; so which model of indoor and outdoor AP can I use to build a Autonomous Wireless Network 802.11n with out using a Wireless LAN Controller.
Leo Laohoo
Hi Antonio,
The AP's mentioned above are indoor AP's built for Draft N (2.0 Ratified). Unfortunately, the 1500/1520 and 1300 outdoor Meshed AP are only A/B/G only.
Data Sheets for the following:
Cisco Aironet 1524 Lightweight Outdoor Mesh Access Point
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps8368/data_sheet_c78-463466.html
Cisco Aironet 1522 Lightweight Outdoor Mesh Access Point
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps8368/product_data_sheet0900aecd8066a16c.html
Cisco Aironet 1500 Series Lightweight Outdoor Mesh Access Points
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps6548/product_data_sheet0900aecd803642e6.html
Cisco Aironet 1300 Series Outdoor Access Point/Bridge
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet09186a00802252e1.html
Cisco Aironet 2.4 GHz and 5 GHz Antennas and Accessories
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008022b11b_ps5861_Products_Data_Sheet.html
