Wireless device cant detect network
James Simpson
Level 3
Level 3
Hi All
I have a test lab setup. I have a uk connection and a German connection.
UK-BO   = UK
DE-BO   =GER
Now I have 2 laptops and both laptops can see both connections no problem.
However I have a tablet. The tablet can see the UK network but not the Germany network. I have tried bouncing the German interface.
I have also tried adding teh network manually on the tablet and resetting to factory default aswell.
I have atteched the config tro see if the wireless guru's may see somethoing in the channel configuration
9 Replies 9
Scott Fella
Try disabling the 5ghz and see if the device can join on the 2.4ghz or set the channel manually on the 5ghz radio.
-Scott
Hi Scott
Thanks for your reply.
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel 2437
station-role root
So are we saying drop 5.5 from the speed above ?
No... Disable the 5ghz radio for testing.
config t
interface Dot11Radio1
shut
-Scott
Ok Thanks I will give it a try
tried shutting dowen the 5Mhz radio still no joy. I e3ven tried the reverse of shutting down the 2.4 and keeping the 5 up
that didnt work either
I would test with another device. It might be a problem with the tablet.
-Scott
Scott Fella
Try to set the SSID to open with no WPA2/AES and see. That will tell you if maybe that the device has an issue with WPA2/AES.
-Scott
I resolved the issue by changing the config of the 5GHZ radio
under interface dot radio 1
I added
antenna gain 0
spped range
channel 5520
The tablet can now see the german wifi
+5 for figuring out the problem:)
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
