Wireless equipment?
edisonbbs
Community Member
Hi All,
I am going setup a wireless project for a hotel.
So, what kind of AP should I use to for indoor and out door?
May I use 1310 for Outdoor? and 1240 or 1200 for indoor?
By the way, may I use Root-brigde with client (Non-root-brigde with client) in 1310 AP? If yes, how large area can be covered by AP for client?
and, what's the main function of the WCS? Thanks
Leo Laohoo
If you have a controller-based environment, the WCS can manage one or more WLC.  Aside from that, the WCS can generate reports that the WLC can't.
Depends on alot of factors.  Firstly you can no longer buy 1200 or 1240.  Next, the 1200-series is designed to use optional external antennas.  For built-in, the can purchase the 1040, 1130, 1140 and 3500i.  Only the 1130 will support 802.11a/b/g.  The rest will support 802.11a/b/g/n.
This depends on alot of factors.  In a wide open space (no walls) you can get up to 40 meters in a single direction.  I'd recommend you get a wireless site survey done.
Please don't forget to rate our useful posts.  Thanks.
