Wireless L3 Roaming
lenkasurat
Level 3
Level 3
Hello Experts,
Hope you are doing well!
I am using 5508 controller and couple of sites are used on Flexconnect mode, I want to know if I can configure L3 roaming on the SSID? if, yes how?
Thanks in advance!
Ric Beeching
Level 11
Level 11
Hi lenkasurat,
For the sites running Flexconnect mode is the SSID set to Local or Central Switching? You will be unable to perform L3 Roaming on the APs in local switching mode. This table below is sort of helpful but see the full feature matrix here:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-product-00.html#anc13
Mobility / Roaming Scenarios
WLAN ConfigurationLocal SwitchingCentral Switching
CCKMPMK (OKC)OthersCCKMPMK (OKC)Others
Mobility Between Same Flex GroupFast Roam(1)Fast Roam(1)Full Auth(1)Fast RoamFast RoamFull Auth
Mobility Between Different Flex GroupFull Auth(1)Fast Roam(1)Full Auth(1)Full AuthFast RoamFull Auth
Inter Controller MobilityN/AN/AN/AFull AuthFast RoamFull Auth
(1) Provided WLAN is mapped to the same VLAN (same subnet).
Please rate helpful / correct posts
Rasika Nayanajith
No L3 roaming support in FlexConnect design (except central switching which is similar to local mode AP deployment).
Rasika
Thank you !! Mananalage & Ric
