Wireless Lan Controller 2500
hello,
I want to configure a wireless lan controller 2500 which reside on a different subnet than some Access points. Is it possible?
8 Replies 8
Stephen Rodriguez
yes, this is achievable so long as you have L3 reachability between the AP and the WLC
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thank you stephen,
this is the part number of my access points:
AIR-CAP3602E-A-K9, Is it possible with this access points?
Hi Akaffou.
Yes co can do it, you can use DHCP option 43 and other methods.
Please check this links
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Thank you Daniel, this is the part number of my access points: AIR-CAP3602E-A-K9, Is it possible with this access points.
Yes you can
Scott Fella
The answer is yes. Take a look at the links that was posted in the previous post.
-Scott
Thank you Scott
Abha Jha
There are many ways to discover AP :-
Methods for discovering an AP
A lightweight access point can be discovered in the following ways:
  • Layer 3 LWAPP discovery: This  discovery occurs when the LWAP is on a different subnet from the WLC and  the AP uses the IP address rather than the Layer 2 MAC address.
  • Layer 2 LWAPP discovery: This  discovery occurs when the LWAP and WLC are on the same subnet and the  discovery data is placed in Ethernet frames that contain the MAC  addresses of the two devices.
    Layer 2 LWAPP discovery cannot be used in Layer 3 environments.
