Wireless LAN Controller + SNMP Version 3 Configuration
Prasan Venky
Level 7
Level 7
Hi all,
Is that required to reboot the controller after we configure SNMP V3 ..? Any related document reffering this ...?
KVS
Looks like I stand corrected!  Even in v7.4, the config guide says you're supposed to reboot the WLC for SNMPv3 config changes to take effect
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_010110.html#d77398e560a1635
9 Replies 9
Richard Atkin
Level 10
Level 10
There are lots of ways to reboot a controller.. can you be more specific in what you're trying to achieve and why?
Actually i just want to know if we configure SNMP V3 on controller, we need to reboot the controller to take effect ..? or reboot is not required ...?
You do not need to reboot the controller. Just configure it and it works.
Thanks for your reply. But i found this in the below link. So bit confused...
Which controller functions require a reboot?
A. After you perform these functions on the controller, you must reboot the controller in order for the changes to take effect:
      • Enable or disable link         aggregation (LAG)
      • Enable         a feature that is dependent on certificates (such as https and web         authentication)
      • Add         new or modify existing SNMP v3 users
      • Install         a license, change the license feature set, or change the priority of an         AP-count evaluation license on a controller
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008064a991.shtml
KVS
That document is REALLY old.
I've just logged in to my WLC (v7.4.100.60) and created an SNMPv3 account without any problems at all. And without rebooting ofc.
Even I feel same here. If you could provide me the latest doc would be a great help. Thnaks in advance
Yes, We need to reboot the controller to take effect but dont know the exact reason behind this ...
Thanks for your help.
iroperto1
Level 2
Level 2
Hi, Richard--
The instruction from cisco said you need to reboot the WLC after configured SNMPv3 in the WLC. Please see attachment below.
