wireless lan controller software upgrade question
Guys
i am having wlc(5508) running with 7.0.220.0 and i am trying to upgrade to recent one 7.6.110.x
wht are nearest release i need upgrade before i ugrade wlc to 7.6.x.x?
any URL with refernce to this?
which is recommnaded recent code?
8 Replies 8
Leo Laohoo
If you want to go 7.6.X then use 7.6.140.0 instead.
You can go "straight" from 7.0.X to 7.6.140.0.  Don't forget to upgrade the FUS code.
Thank you Leo
i see 7.6.130.0(ED) on cisco websites,there is no 7.6.140.0 listed here,
is still ok to go with 7.6.130.0(ED)?
wht is correct FUS code for 7.6.130.0 ? i am not finding here
The FUS is listed in the downloads.  It is 1.9 and con be found in the link below.  Please read the release notes on installing the FUS as it can take 35-45 minutes to complete.
https://software.cisco.com/download/release.html?mdfid=282600534&flowid=7012&softwareid=284364857&release=1.9.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest
-Scott
-Scott
Thank you scott....i got it
Typo on my part.  Sorry.
The latest is v7.6.130.0 there is no v7.6.140.0, it must of been a typo.
-Scott
-Scott
J. Adams
Level 2
Level 2
Keep in mind that there are no plans for 7.6.140.0 release so if you would like to get the various security fixes found in 7.4.140.0 or 8.1, you can use a 7.6.130.x engineering release for some (Poodle Vulnerability) or the next step would be 8.0.120.0 .  Pleae see the release notes for resolved bugs for complete list.
