Wireless LAN Controller- WLAN/SSID
siddhartham
Level 9
Level 9
Can we assign the smae SSID to different VLANS on the wireless lan controller?
Siddhartha
Leo Laohoo
Depends on the firmware you are running.
If you are running 7.0.116.0 then you can use a feature called Interface Groups.
Leo Laohoo
We are running 7.0.98.0,does the feature work with it.If you don't mind can you also send some documentation explaining the feature.
Siddhartha
Found the documentation on Cisco's website, thanks for the quick reply
Siddhartha
Leo Laohoo
Thanks for the rating.
