wireless LAN controllers (WLCs) Question
stephen.bel0001
Community Member
How do I know if my two wireless LAN controllers (WLCs) have properly paired up?
Hello Stephen,
use below command
To check the redundancy state of the active WLC from the Cisco Prime ™ Network Control System (NCS), go to Device Details > Redundancy > Redundancy States
In CLI - The pair up details will be seen under - “show redundancy summary”.
Hello Stephen,
use below command
Charles Hill
Hello ,
Go to
-> Controller
-> Mobility Management
-> Mobility Groups
-> The WLC's will be listed and status will show "Up"
Hopefully this answers your question.
Please rate helpful posts.
Thanks.
