Wireless LAN IOS upgrade
Hello Team,
We are using Cisco Wireless Model- AIR-CT2504-K9.We are planning for IOS upgrade.
Current version - 8.2.151.0
Want to upgrade - 8.5.140.0
Could please suggest what are the precautions/steps needs to be taken before doing this.
Also provide procedure for ios upgrade.
Below APs are connected . Will it support new code.Kindly help.
AIR-CAP1702I-B-K9
AIR-CAP3502I-A-K9
Kanhu
2 Accepted Solutions
   Pretty straightforward. If we were talking about a very large environment, I´d recommend to pre-download AP images, but, that´s not the case.  Just go for it.
https://www.youtube.com/watch?v=vCFODVsEi64
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
-If I helped you somehow, please, rate it as useful.-
Haydn Andrews
The first step in any upgrade is to check the compatibility of the WLC/ APs with the code version. In your case they all are supported on 8.5.140: https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
I will quite often do a pre-download to the APs.
Plan on at least 30-40 minutes for the APs to reload, upgrade etc when you hit reload on the WLC
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
Read the Release Notes very carefully. It is not possible to go straight from 8.2.X.X to 8.5.X.X without upgrading to 8.3.X.X first.
Haydn Andrews
