Wireless lan not connected.
Larry11
Community Member
The inbuilt WiFi has been getting flaky and now won't connect on my Panasonic cf52 win 7 laptop. Initially it would disconnect and the lights would be flashing and eventually reconnect. I have replaced the card a number of times and this time the card lasted a very short time. Weirdly I noticed the problems seemed to coincide with avg needing a scan which makes me wonder if this is a software problem In device manager the card is detected and working. In the network and sharing centre it says the adapter is not connected. Any one with ideas out there....
https://pincodes.gen.in/
https://indianpin-code.in/
Leo Laohoo
What firmware is the WLC/AP running on?
Rich R
Like @Leo Laohoo said but also get rid of AVG and use the Microsoft AV product instead (I did years ago).
https://www.microsoft.com/en-gb/download/details.aspx?id=5201
A fresh install of Windows could also help if the registry has got corrupt.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
