Wireless Licensing model
i_mohamed
Frequent Visitor
Frequent Visitor
A customer would like to have WLAN setup with Cisco controller ONLY (no DNA/Catalyst center). AP to be used is 9105.
What licenses are required is mandatory in this case?
8 Replies 8
@i_mohamed
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/impl-catalyst-9800-wrls-lan-ctrlr-licens-faq.html
On this link you can find all your answer. Most specifically, this part:
"Q.  Which license do I need for access points that are joined to my Catalyst 9800 WLC?
A.   Every access point joined to a Catalyst 9800 controller consumes one (1) AIR Network license and one (1) AIR DNA license.
Once purchased, these licenses show up in your smart account, which can be accessed Here.
Both of these licenses can be configured to be either Essential or Advantage level. An example of a controller configured with an "
So, Cisco create this system where the WLC itself does not require any license but, for each Access Point joined,  AIR Network license and one (1) AIR DNA license.
If you are planning to buy, you need to get in contact with a Cisco reseller anyway. My advise is for you to talk with them and get all your answers. Dont rely only in technical documentation as this is mostly a commercial operation.
Thanks .. these are perptual licenses - not subscription correct? as AIR DNA lic usually are subscription based (1, 3, 5, or 7 years)?
If it is a subscription based: what happenes if not renewed?
There is a NETWORK license (perpetual) and the DNA license (subscription based) which is only required for "DNA" features (including Cisco Spaces).
The catch is that you can only get the perpetual license by buying the DNA subscription which comes bundled with the perpetual network license (so buying an initial DNA subscription is mandatory).
Once the subscription expires you keep running the AP on the WLC with the network license only.  Changing the WLC config (from DNA to network only) requires a reload so if you are not using DNA then best to configure for network only from day 1 otherwise you start getting regular warnings when the DNA expires.
So then you just need to choose between Essential and Advantage which affects what features can be used.  Some HA features are only supported with Advantage.  Despite what one of the other replies suggests you cannot mix Essential and Advantage - the WLC is configured for one or the other and every AP on that WLC must be using the same.
So far ... the only license enforcement in place (apart from frequent syslog warnings) is that the 9800-CL is limited to 50 APs unless you have an active connection to smart licensing - but that could change at any time
The WiFi 7 APs move to a Meraki style Network Subscription per AP (no more perpetual license) which includes basic RMA support (upgrading to higher RMA levels is optional extra).  Cisco talked about disabling all except 2.4GHz radio on the AP until it has a valid active subscription (still mentioned in one of the docs online) but so far have not implemented or enforced this.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
balaji.bandi
For an AP to join a Cisco Catalyst 9800 Series Wireless Controller (WLC), a Cisco DNA subscription license is mandatory at the time of purchase, even if you do not plan to use Cisco Catalyst Centre (formerly DNA Centre).
check ordering guide :
https://www.cisco.com/c/dam/global/en_sg/solutions/small-business/pdfs/cisco-catalyst-9105-series-access-points-brochure.pdf
https://www.cisco.com/c/en/us/td/docs/wireless/controller/licensing/b-sl-using-policy-wireless-controllers.html#Cisco_Concept.dita_7d112493-86f2-4933-8d4b-c3ad35b0f6c6
BB
And besides licensing, if the APs are not yet bought, think about going for CW9172 or CW9171. They will be supported much longer than the 9105.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
@i_mohamed Cisco 9105 APs with a standalone WLC require Cisco DNA Advantage licenses (per AP, term-based), as the 9105 series mandates DNA licensing even without DNA/Catalyst Center — the controller enforces it
i_mohamed
Frequent Visitor
Frequent Visitor
What about the new generation of WiFi7 APs? what is different? i saw some statements about licensing requirements for 917x WiFi7 APs.
The Wi-Fi 7 APs need a Cisco Wireless Essential Subscription:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/wireless-wi-fi-7-access-points-aag.html
