Wireless Mesh with Local mode APs
jagan.chowdam
Hi All,
I've a customer who is expanding their office to a building across street and they want to implement following design.
WLC --SWITCH1-- RAP -- MESH --- MAP -- SWITCH2 -- LOCAL MODE APs
Will this design works? If yes, what should be the configuration on
  • SWITCH 1 interface where the RAP is connected
  • SWITCH 2 interface where the MAP is connected
  • SWITCH 2 interfaces where LOCAL MODE APs are connected
  • WLC MESH configuration.
CJ
jagan.chowdam
Found the answer: CAPWAP over CAPWAP is not supported and thus the following design will not work.
But what if I configure one of the Local Mode APs behind the MAP as Mobility Express controller and join the rest of the Local mode APs to this ME, then will it work?
WLC --SWITCH1-- RAP -- MESH --- MAP -- SWITCH2 -- Mobility Express -- Local Mode APs
Can I keep them (all devices shown above) on flat network (VLAN 1), without any additional VLANs going through the Mesh?
CJ
CJ did you get a reply to your question?
