12-24-2010 03:50 AM - edited 07-03-2021 07:35 PM
hello I have a problem with my wireless router, cisco wireless module allows you to give different IP addresses so that IP addresses are different who can help me please
01-01-2011 01:30 AM
I have one it's files uploaded to the router, but the local client can not get the same IP address for wireless APIPA addres
01-01-2011 09:07 AM
The Wired and the Wireless will not get the same IP address.. the wired will get from 10.10.10.X network.. the wireless will get it from 20.20.20.X network..
now please let me know if your Wired clients are getting the IP address or not?? What the is the issue that we are facing?? coz the latest config which i have posted works completly fine..
I am attaching the configs and please implement it and let me know if the wireless clients are getting in 20.20.20.x network and wired in 10.10.10.x network..
I have changed the VLANs on the router.. Your WIRED = VLAN2 = 10.10.10.X and WIRELESS = VLAN 1 = 20.20.20.x (Because of simple configs on the Wireless AP).
Surendra
01-01-2011 09:41 AM
20.20.20.0 get the wireless clients that is good but if I ssh or telnet to 20.20.20.1 and wire it will not I get no ip address?
01-01-2011 09:51 AM
are the wireless clients getting the IP? are they able to go out to the internet?? The wired will get the IP from VLAN 2 (10.10.10.X) network.. are they not getting??
01-01-2011 10:01 AM
Yes the wireless get a ip that is fine but if I ssh or telnet to the wireless ip 20.20.20.1 does not do the clients get no ip wire
01-01-2011 10:08 AM
if you connect your PC or laptop to port fa 4 interface.. are we getting the ip in 10.10.10.X network??
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
01-01-2011 10:12 AM
Wireless subnet VLAN ip address is 20.20.20.1 but, to access the Wireless Aceess point.. the IP should be 20.20.20.2
i am not able to understand "but if I ssh or telnet to the wireless ip 20.20.20.1 does not do the clients get no ip wire" what does this mean??
Surendra
01-01-2011 10:16 AM
okay now that the wire work that clients get no ip address
01-01-2011 10:19 AM
so the wired network is not working??
Surendra
01-01-2011 10:22 AM
no, I get an APIPA address but no ip from dhcp
01-01-2011 10:25 AM
On which interface on the router you are connected wired?? assigning a static IP address works??
Since wireless portion is resolved, it will be great if you could mark this post as ANSWERED
Surendra
01-01-2011 10:36 AM
I am connected wired interface on 4 but I also tried the other ports but not ip
and with a static ip does it not
01-01-2011 10:39 AM
ok.. so.. is the configuration under the fa 4 interface like below??
interface FastEthernet4
switchport mode access
switchport access vlan 2
Surendra
01-01-2011 10:55 AM
there just switch port access vlan 2
another switch port mode access
01-01-2011 11:03 AM
Ok.. I wonder how can this happen?? its a flat network.. from the router are u able to ping 10.10.10.1??
Surendra
