wireless module different IP addresses
pcfreak49
hello I have a problem with my wireless router, cisco wireless module allows you to give different IP addresses so that IP addresses are different who can help me please
67 Replies 67
you mean so
the int vlan needs in the AP?
int vlan should be on the Router not on the AP..
that is..
on the router
int vlan 1
ip addr 20.10.10.1 255.255.255.248
no shut
end
On the AP
int bvi 1
ip addr 20.10.10.2 255.255.255.248
no shut
end
ip dhcp pool R2.ap-pool
   import all
   network 20.10.10.0 255.255.255.248
   domain-name home.be
   default-router 20.10.10.2
The above will do!!
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
did that work??
Surendra
Surendra BG
so these are the two running-config of the router and AP
hope it's true
Now its nice to troubleshoot since we have both the running configs!! yes u are right.. we have 2 running configs one on the AP and other on Router..
the config is very badly messed up on the router and the AP.. please answer the below questions..
I can see VLAN 1 and VLAN 2 configured.. and the WLAN-AP 0 is mapped to come other subnet..This will not work.. the AP ahould be either in VLAN 1 subnet or VLAN 2..
1>> Lemme know in which subnet u need the same??
2>> In which subnet do u want your wireless clients to get the IP??
i have attached the config which i am using in my LAB.. please check that out and lemme know if u have any doubts..
Surendra
Surendra BG
Please let me know ur requirements.. i will try to modify the confiug and help u out in getting the network up and running!!
Surendra
Surendra BG
lemme know if ur facing some issues with internal DHCP
Surendra
Surendra BG
Thanks to the two running-config of the router now I can compare
and see what I need to change
If I send files through wireless and then reboot the wireless module
do you think?
Ok.. i am sorry.. i did not understand "If I send files through wireless and then reboot the wireless module do you think?" please brief me out..
Please dont forget to mark the posts as answered if this was helpfull..
Surendra
Surendra BG
yes I have a 800 series router when I send files to a different device than the wireless module will reboot I thought maybe it has to do with same network is shared
Hmm.. may be not sure.. have not come across anything like this till now!!
Surendra
Surendra BG
if you've even done a couple of files are sent by wireless mb or gb?
I leave tomorrow or the day you definitely know if it works or not
ok!! will be looking forward to hear from you!!
Surendra
Surendra BG
I've tried but can not
