wireless music streamen
pcfreak49
Level 7
Level 7
hello I do not have a problem with the wireless module Hertzian music streamen always succeed the module reboot know there a sometimes someone solution??
10 Replies 10
Serge Yasmine
hello, sorry i couldn't understand the question. can you explain a bit more?
Okay I will empty out the other a cisco wireless router and am connected wirelessly and stream music and then reboot the wireless module may happen if I copy and move files if anyone solve a
so I understand you have a wireless module for music streaming, and when you are listening to music over wireless the modul restarts on its own.
check for any driver update for your wireless module as this appears to be a client side issue.
question: what kind of wireless access point are you using? can you tell me its model number and how have you configured the ssid?
okay this is the running-config of the wireless module so I have it configured
you access point configuration is looking good.
if your wireless music box is restarting when using it with wifi, as i told you, get intouch with its vendor or search for some new drivers and so on.
've used other drivers on the PC and the result is not no media center update for the wireless module, need it for my final work ?
on the AP please issue this command and lemme know if the issue gets resolved..
issue the command  "no ip igmp snooping" or "no ip igmp snooping vlan  " on the AP CLI..
Lemme know if this answers your question..
Surendra
Please dont forget to rate the useful posts which answered your question or was helpfull
Surendra BG
okay I give it a try and then add music and send a file hopefully it works
because it can not be a professional unit with son
I'll let you know something sebiet
Ok.. i will be looking forward to hear from you!!
Surendra
Surendra BG
no it does not work when I stream files and reboot the wireless module sends automatic
