Wireless PCMCIA Card Support for 1200 Series AP
matt.austin
All,
I am looking for a list of Wireless NIC Cards that are supported by Cisco for communicating with a 1200 Series Cisco AP. I am looking to use LEAP as well, but cannot find documentation on what hardware models are supported for my situation. Any help or direction is greatly appreciated!
Matt
Aaron Harrison
Matt
This link outlines the Cisco Compatible Extensions program:
http://www.cisco.com/en/US/partners/pr46/pr147/partners_pgm_brochure.html
From the table on that page you can see that LEAP is supported by anything that claims even v1 support for Cisco Compatibility...
This next link lists compatible series of laptops and adapters:
http://www.cisco.com/en/US/partners/pr46/pr147/partners_pgm_partners_0900aecd800a7907.html
As LEAP support is required for v1, anything on this page should work for you if that's your only requirement...
Aaron
please rate my post...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks Aaron, just what I was looking for!
