Wireless performance
aksher
Level 7
Level 7
how to measure the performance on AP,
am getting very slow response time.the ping response from AP to the server is normal and also no errors are found on the switch too.
Hi John, did you refer the wrong link ? It looks like not related to this topic....
For the question, there are lots of factor to affect the WLAN performance. Please tell more about the distance, environment, setting, etc.
You can just use a FTP to test the WLAN throughput.
