Wireless Security Question
schadmin
Level 3
Level 3
I want to make all of our wireless clients (Win 2000 and XP) dynamically have their connection, vlan, SSID etc to be handed to them when their pc starts up. We have Cisco ACS 4.0 and I would assume I have to use that with 802.1x. I guess what I am confused is with all the different protocols (LEAP, PEAP, EAP-TLS...etc) and which to use. I was looking for any suggestions from other people who have implemented dynamic wireless LAN's.
followurself
Level 5
Level 5
You will be using 802.1x. The different protocols you mentioned are used for authentication. The most secure out of these is EAP-TLS because it uses certifcates with mutual authentication
Looks like you are looking for machine authentication
Read the doc below
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/wificomp.mspx
for the vlan assignment you can use group attributes
Tunnel-Private-Group-ID you will not see it in by default you need to check this option going into advance
And yes for machine authentication you wd need a registry settings on XP
Are you going to integrate it with Active Directory
