wireless security
huwyhuwy123
Level 3
Level 3
Hi All,
I was hoping someone more knowledgeable than I could cast their eye over the config of our cisco aironets as I have been told "they may be insecure".
Wireless access is active directory integrated so users logon with their active directory username and password.
I'd be grateful to hear any comments on the setup. Thanks!
Al
Scott Fella
The wireless is open and that is why people are telling you that, "it may be insecure". Not knowing what model access point you have, you might want to look at this link.
Autonomous - Configuring Security Solutions
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_configuration_examples_list.html
If you don't have a radius server to authenticate users (EAP), then try using WPA-PSK.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c40b6.shtml
Also the code you are running is pretty old.
-Scott
