09-02-2016 01:24 AM - edited 07-05-2021 05:46 AM
Hello Everyone
In our one project after implementation of wireless project
i had done post survey for wireless heatmaps
i had getting signal strength is good for which -67dbm for both 2.4 & 5ghz
but the problem which i am facing bad Network Health and channel overlaps are more
in controller we change the autotunning for channel for one floor for both 2.4 and 5ghz and some APS we change the transmit power to 2
for that one floor which we tunned we are getting good network health and channel overlap the report for combined 2.4 and 5ghz
but for single report 2.4 and 5 ghz the report for Network Health and channel overlap are not good
for postsurvey the tools i am using ekahau
when i am using the ekahau tool every time tool mesage upgarded latest version or skip version
for postsuvey for main thing for approved heatmaps like
1 signal strength should be -65 or -67 dbm
Support in this regard will be highly appreciated.
Solved! Go to Solution.
09-02-2016 04:35 PM
Wait a second. I've seen this floor map before!
Are there two of you working on this issue?
09-03-2016 07:56 PM
Syed,
if you have a high density of AP's you will most likely always see channel overlap on the 2.4ghz and dependent BG in the channel width used on the 5ghz and available channels, you can also see channel overlap. It's always good to set the max/min TX power and then test areas. You can use AP groups along with RF profiles to tune your network. Areas that are more open vs closed areas vs hallway, you can force limits to get your power where it needs to be in which one AP doesn't overpower an adjacent AP in which a client will tend to favor. Take an area at a time and play around with power and data rates until you find a sweet spot that works well. this depends on how much time you want to play around and learn the RF in the environment. Client devices and applications play a role also, but you should be able to still find a sweet spot.
-Scott
09-02-2016 04:35 PM
09-03-2016 01:44 PM
Thanks Leo Laohoo
yes i was not ware
Any suggestions regarding this Network health and channel overlap
09-03-2016 07:56 PM
Syed,
-Scott
09-03-2016 10:54 PM
Thanks Scott Fella
