WIRELESS to WIRED
kuriakose1
I'm searching for a solution to convert Wi-Fi to LAN
I have an area where 1G WIFI available but I need to provide  network connectivity to 10 desktop via ethernet
Is there any product I can use to convert the Wifi signal to LAN  and deliver via a switch to desktop
5 Replies 5
Hello
 You can use mesh network. Mesh network allows you to convert the Wi-Fi network into a wired network.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/b_mesh_87/b_mesh_87_chapter_0110.html
Hello
Seems a good solution, can you suggest a Cisco model of APs or other brand models of APs that can use to connect 10 workstations
sure.
It depends on how much you are willing to spend, but I will suggest you some midle range:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1850-series-access-points/datasheet-c78-734256.html
Leo Laohoo
Wait, this does not make any sense.
"1G WiFi"?  Is this WiFi or 3G/4G/5G/LTE?
For 10 desktops, it is cheaper to get a 5.0 Ghz WiFi USB dongle.
